network fcp topology show
FCP topology interconnect elements per adapter
Display FCP topology interconnect elements per adapter.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-node {<nodename>|local}]- Node
Use this parameter to select the interconnect elements for adapters that are located on the node that you specify.
- [-adapter <text>]- Adapter
Use this parameter to select the interconnect elements for the specified adapter.
- [-domain-id <integer>]- Domain Id
Use this parameter to select the interconnect elements with the specified domain identifier.
- [-port-wwpn <text>]- Port WWPN
Use this parameter to select the interconnect elements with the specified port world wide name.
- [-switch-name <text>]- Switch Name
Use this parameter to select the interconnect elements with the specified switch.
- [-switch-vendor <text>]- Switch Vendor
Use this parameter to select the interconnect elements with the specified vendor.
- [-switch-release <text>]- Switch Release
Use this parameter to select the interconnect elements with the specified release.
- [-switch-wwpn <text>]- Switch WWPN
Use this parameter to select the interconnect elements with the specified world wide port name.
- [-switch-wwn <text>]- Switch WWN
Use this parameter to select the interconnect elements with the specified world wide name.
- [-port-count <integer>]- Port Count
Use this parameter to select the interconnect elements with the specified port count.
- [-port-slot <text>]- Port Slot
Use this parameter to select the interconnect elements with the specified port slot.
- [-port-state {Unknown|Online|Offline|Testing|Fault}]- Port State
Use this parameter to select the interconnect elements with the specified port state.
- [-port-type {None|N-Port|NL-Port|FNL-Port|NX-Port|F-Port|FL-Port|E-Port|B-Port|TNP-Port|TF-Port|NV-Port|FV-Port|SD-Port|TE-Port|TL-Port}]- Port Type
Use this parameter to select the interconnect elements with the specified port type.
- [-port-attached-wwpn <text>]- Attached Port WWPN
Use this parameter to select the interconnect elements with the specified attached wwpn.
- [-port-attached-id <text>]- Attached Port Id
Use this parameter to select the interconnect elements with the specified attached id.
- [-port-attached-visible <text>]- Visible
Use this parameter to select the interconnect elements with the specified visiblity flag on attached port structure.
cluster1::> network fcp topology show
Switch connected to the adapter 0c
      Switch Name: ssan-fc0e-d58
    Switch Vendor: Cisco Systems, Inc.
   Switch Release: 5.2(1)N1(9)
    Switch Domain: 4
       Switch WWN: 20:05:00:05:9b:26:f4:c1
       Port Count: 20
Port    Port WWN                State     Type      Attached WWPN           Port Id
vfc9    20:08:00:05:9b:26:f4:ff Offline   None      -                       -
vfc10   20:15:00:05:9b:26:f4:ff Online    TF-Port   50:0a:09:82:8d:92:4c:ff 0x0407c0  *
vfc11   20:16:00:05:9b:26:f4:ff Online    TF-Port   50:0a:09:81:8d:e2:4e:ec 0x040800  *
    Switch Domain: 4
       Port Count: 20
vfc20   20:13:00:05:9b:26:f4:ff Offline   None      -                       -
vfc21   20:14:00:05:9b:26:f4:ff Online    TF-Port   50:0a:09:81:8d:92:4c:ff 0x0407a0  *
5 entries were displayed.
The example above show FCP topology interconnect information for the cluster.
 PDFs
PDFs
