storage iscsi-initiator show
Display the iSCSI targets
The storage iscsi-initiator show displays the list of iSCSI targets configured for each Data ONTAP node in the cluster. This command is only supported on high-availability shared-nothing virtualized platforms.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
Represents the name of the Data ONTAP node for which information is to be displayed. If this parameter is not specified, the command displays information about all nodes in the cluster.
[-target-type {external|mailbox|partner|partner2|dr_auxiliary|dr_partner}] - Target Type
Selects targets with the specified target type.
[-label <text>] - User Defined Identifier
Selects targets with the specified label.
[-target-portal <text>] - Target Portal
Selects targets with the specified portal.
[-target-name <text>] - iSCSI Name
Selects targets with the specified target name.
[-status-admin {down|up}] - Administrative Status
Selects targets with the specified administrative status.
[-status-oper {down|up}] - Operational Status
Selects targets with the specified operational status.
[-failure-reason <text>] - Failure Reason
Selects targets with the specified failure reason.
The following example displays the list of iSCSI targets for each node in the cluster.
cluster1::*> storage iscsi-initiator show
        Status
Node Type Label    Target Portal      Target Name                      Admin/Op
node1
     mailbox
          mediator 10.235.14.141      iqn.2012-05.local:mailbox.group.1  up/up
     partner
          partner  10.63.7.205:65200  iqn.2012-06.com.bsdctl:target0     up/up
node2
     mailbox
     partner
          partner  10.63.7.201:65200  iqn.2012-06.com.bsdctl:target0     up/up
4 entries were displayed.
