storage iscsi-initiator show
Display the iSCSI targets
The storage iscsi-initiator show
displays the list of iSCSI targets configured for each Data ONTAP node in the cluster. This command is only supported on high-availability shared-nothing virtualized platforms.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
Represents the name of the Data ONTAP node for which information is to be displayed. If this parameter is not specified, the command displays information about all nodes in the cluster.
[-target-type {external|mailbox|partner|partner2|dr_auxiliary|dr_partner}]
- Target Type-
Selects targets with the specified target type.
[-label <text>]
- User Defined Identifier-
Selects targets with the specified label.
[-target-portal <text>]
- Target Portal-
Selects targets with the specified portal.
[-target-name <text>]
- iSCSI Name-
Selects targets with the specified target name.
[-status-admin {down|up}]
- Administrative Status-
Selects targets with the specified administrative status.
[-status-oper {down|up}]
- Operational Status-
Selects targets with the specified operational status.
[-failure-reason <text>]
- Failure Reason-
Selects targets with the specified failure reason.
The following example displays the list of iSCSI targets for each node in the cluster.
cluster1::*> storage iscsi-initiator show Status Node Type Label Target Portal Target Name Admin/Op ---- ---- -------- ------------------ -------------------------------- -------- node1 mailbox mediator 10.235.14.141 iqn.2012-05.local:mailbox.group.1 up/up partner partner 10.63.7.205:65200 iqn.2012-06.com.bsdctl:target0 up/up node2 mailbox mediator 10.235.14.141 iqn.2012-05.local:mailbox.group.1 up/up partner partner 10.63.7.201:65200 iqn.2012-06.com.bsdctl:target0 up/up 4 entries were displayed.
