storage iscsi-initiator show
Display the iSCSI targets
The storage iscsi-initiator show displays the list of iSCSI targets configured for each ONTAP node in the cluster. This command is only supported on high-availability shared-nothing virtualized platforms.
[-fields <fieldname>,…]-
If you specify the
[-instance ](privilege: advanced) } -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node (privilege: advanced)-
Represents the name of the ONTAP node for which information is to be displayed. If this parameter is not specified, the command displays information about all nodes in the cluster.
[-target-type {external|mailbox|partner|partner2|dr_auxiliary|dr_partner}]- Target Type (privilege: advanced)-
Selects targets with the specified target type.
[-label <text>]- User Defined Identifier (privilege: advanced)-
Selects targets with the specified label.
[-target-portal <text>]- Target Portal (privilege: advanced)-
Selects targets with the specified portal.
[-target-name <text>]- iSCSI Name (privilege: advanced)-
Selects targets with the specified target name.
[-status-admin {down|up}]- Administrative Status (privilege: advanced)-
Selects targets with the specified administrative status.
[-status-oper {down|up}]- Operational Status (privilege: advanced)-
Selects targets with the specified operational status.
[-failure-reason <text>]- Failure Reason (privilege: advanced)-
Selects targets with the specified failure reason.
The following example displays the list of iSCSI targets for each node in the cluster.
cluster1::*> storage iscsi-initiator show
Status
Node Type Label Target Portal Target Name Admin/Op
node1
mailbox
mediator 10.235.14.141 iqn.2012-05.local:mailbox.group.1 up/up
partner
partner 10.63.7.205:65200 iqn.2012-06.com.bsdctl:target0 up/up
node2
mailbox
partner
partner 10.63.7.201:65200 iqn.2012-06.com.bsdctl:target0 up/up
4 entries were displayed.
