The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
security key-manager delete-key-database
PDF of this doc site
Creating your file...
Your file is ready
(DEPRECATED)-Deletes the key hierarchy for the Onboard Key Manager
This command is deprecated and might be removed in a future release. Use security key-manager onboard disable instead. |
The security key-manager delete-key-database
command permanently deletes the Onboard Key Manager configuration from all nodes of the cluster.
The following example deletes the Onboard Key Manager configuration from all nodes of the cluster:
cluster-1::*> security key-manager delete-key-database Warning: This command will permanently delete all keys from the Onboard Key Manager. Do you want to continue? {y|n}: y
