Command reference
vserver security trace filter delete
Delete a security trace entry
The vserver security trace filter delete command deletes a security trace filter entry. Prior to ONTAP 9.3, this feature was only supported for CIFS. In ONTAP 9.3 and later, this feature is supported for both NFS and CIFS.
-vserver <vserver name> - Vserver
This parameter specifies the name of the Vserver on which the tracing filter entry that you want to delete is applied.
-index <integer> - Filter Index
This parameter specifies the index number for the filter that you want to delete. You can display a list of the filter index numbers by using the vserver security trace filter show command.
The following example deletes a security trace filter.
cluster1::> vserver security trace filter delete -vserver vs0 -index 1
