lun igroup initiator show
Display initiators
This command displays information for initiators that are members of initiator groups (igroups).
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]- Vserver-
Selects the initiators of igroups whose Vserver matches the specified value.
[-initiator <text>]- Initiator-
Selects initiators whose name matches the specified value.
[-comment <text>]- Comment-
Selects initiators whose comment matches the specified value.
[-igroups <text>,…]- Igroups-
Selects initiators belonging to the specified igroups.
[-proximal-vservers <text>,…]- Proximal Vservers (privilege: advanced)-
Selects initiators configured as proximal to the specified Vservers.
cluster1::> lun igroup initiator show -instance Vserver: vs0 Initiator: init1 Comment: Initiator Comment Igroups: ig1,ig2 Vserver: vs0 Initiator: init2 Comment: Initiator Comment2 Igroups: ig3 2 entries were displayed.
This example displays detailed information for all initiators in igroups.
