system switch ethernet interface show
Display interface information for Ethernet switches (cluster and storage).
The system switch ethernet interface show command displays the status and configuration of network interfaces on the monitored switches.
[-fields <fieldname>,…] -
Selects the fields that you specify.
[-counters ] -
Displays the current status of the following network counters:
in-octets
in-errors
in-discards
out-octets
out-errors
out-discards
[-instance ]} -
Displays detailed interface configuration for all monitored Ethernet switches
[-device <text>]- Switch Name-
Selects the interface ports that belong to the specified switch.
[-interface-name <text>]- Interface Name-
Selects the interface ports that match the specified interface name.
[-index <integer>]- Interface Index-
Selects the interface ports that match the specified interface index.
[-type <interface type>]- Interface Type-
Selects the interface ports that match the specified interface type.
[-mtu <integer>]- MTU-
Selects the interface ports that match the specified maximum transfer unit.
[-duplex-type {unknown|half-duplex|full-duplex}]- Duplex Settings-
Selects the interface ports that match the specified duplex setting.
[-speed <integer>]- Interface Speed(Mbps)-
Selects the interface ports that match the specified interface speed in bits per second.
[-admin-state {up|down|testing}]- Adminstrative Status-
Selects the interface ports that match the specified administrative status of the switch interface.
[-oper-state {up|down|testing|unknown|dormant|not-present|lower-layer-down}]- Operational Status-
Selects the interface ports that match the specified operational status.
[-is-isl {yes|no}]- Is ISL-
Selects the interface ports that are Inter-Switch links (yes) or are not Inter-Switch links (no).
[-in-octets <Counter>]- Input Octets-
Selects the interface ports that match the specified number of octets entering the interface.
[-in-errors <Counter>]- Input Errors-
Selects the interface ports that match the specified number of input packets that were dropped due to errors.
[-in-discards <Counter>]- Input Discards-
Selects the interface ports that match the specified number of input packets that were silently discarded (possibly due to buffer overflow).
[-out-octets <Counter>]- Output Octets-
Selects the interface ports that match the specified number of octets that exited the interface.
[-out-errors <Counter>]- Output Errors-
Selects the interface ports that match the specified number of output packets that were dropped due to errors.
[-out-discards <Counter>]- Output Discards-
Selects the interface ports that match the specified number of output packets that were silently discarded (possibly due to buffer overflow).
[-timestamp <MM/DD/YYYY HH:MM:SS>]- Stats Retrieval Timestamp-
Selects the interface ports with statistics collected at the specified timestamp.
[-interface-number <integer>]- Interface Number-
Selects the interface ports that match the specified interface number.
[-unique-name <text>]- Interface Unique Name-
Selects the interface port that matches the specified unique name.
[-display-name <text>]- Interface Display Name-
Selects the interface ports that match the specified display name.
[-status {ok|ok-with-suppressed|degraded|unreachable|unknown}]- Port Config Status-
Selects the interface ports that match the specified status.
[-monitor {node-connect|system-connect|system|controller|chassis|cluster-switch|example|ethernet-switch}]- Health Monitor-
Selects the interface ports that the specified health monitor continuously monitors.
[-switch-type {cluster-network|storage-network}]- Switch Network-
Selects the interface ports that match the specified switch type.
[-remote-port-mtu <integer>,…]- MTU of Remote Port-
Selects the interface ports that match the specified remote port mtu.
[-remote-port-name <text>]- Remote Port Name-
Selects the interface ports that match the specified remote port name.
[-remote-device <text>]- Remote Device Name-
Selects the interface ports that match the specified remote device.
[-model <text>]- Switch Model-
Selects the interface ports that match the specified model.
[-mac-address <text>]- MAC Address-
Selects the interface ports that match the specified mac address.
[-vlan-id <text>]- VLAN ID-
Selects the interface ports that match the specified vlan id.
[-if-alias <text>]- Interface Alias-
Selects the interface ports that match the specified interface alias.
[-is-vpc-peer-link {yes|no}]- Is vPC Peer Link Interface-
Selects the interface ports that are part of the vPC peer link (yes) or are not part of the vPC peer link (no).
[-role <text>]- Role-
Selects the interface ports that are configured for the specified role.
[-breakout-physical-port <text>]- Breakout Physical Port-
Selects the breakout interface ports with the specified physical interface name.
[-breakout-number <integer>]- Breakout Number-
Selects the breakout interface ports with the specified sub-interface number.
[-slot <integer>]- Slot-
Selects the interface ports in the specified slot.
cluster1::> system switch ethernet interface show
Switch: SwitchA
Opera-
Num- Admin tional Is
Interface ber Index Type Status Status ISL MTU Duplex Speed
Ethernet1/ 1 436207616 ethernetC up up no 1500 full- 40000
1 smacd duplex
Ethernet1/ 10 436244480 ethernetC up down no 1500 full- 40000
10 smacd duplex
Switch: SwitchB
Opera-
1 smacd duplex
10 smacd duplex
The example above displays the interfaces on all Ethernet switches (cluster, management and storage).
cluster1::> system switch ethernet interface show -counters Switch: SwitchA In Out Out Interface In Octets In Errors Discards Out Octets Errors Discards ----------- ------------- --------- -------- ------------ -------- ----------- Ethernet1/1 1856922869 177091 0 3122212606 0 2 Ethernet1/ 3242386021 0 0 1408092011 0 74 10 Switch: SwitchB In Out Out Interface In Octets In Errors Discards Out Octets Errors Discards ----------- ------------- --------- -------- ------------ -------- ----------- Ethernet1/1 1281177979 182012 0 3271353786 0 1 Ethernet1/ 3611218526 0 0 2626671058 0 0 10
The example above displays the counters on switch network interfaces for all the Ethernet switches (cluster, management and storage).
