system switch ethernet interface show
Display interface information for Ethernet switches (cluster, management and storage).
The system switch ethernet interface show command displays the status and configuration of network interfaces on the monitored switches.
{ [-fields <fieldname>,…​]
Selects the fields that you specify.
| [-counters ]
Displays the current status of the following network counters:
  • in-octets
  • in-errors
  • in-discards
  • out-octets
  • out-errors
  • out-discards
| [-instance ] }
Displays detailed interface configuration for all monitored Ethernet switches
[-device <text>] - Switch Name
Selects the interface ports that belong to the specified switch.
[-interface-name <text>] - Interface Name
Selects the interface ports that match the specified interface name.
[-index <integer>] - Interface Index
Selects the interface ports that match the specified interface index.
[-type <interface type>] - Interface Type
Selects the interface ports that match the specified interface type.
[-mtu <integer>] - MTU
Selects the interface ports that match the specified maximum transfer unit.
[-duplex-type {unknown|half-duplex|full-duplex}] - Duplex Settings
Selects the interface ports that match the specified duplex setting.
[-speed <integer>] - Interface Speed(Mbps)
Selects the interface ports that match the specified interface speed in bits per second.
[-admin-state {up|down|testing}] - Adminstrative Status
Selects the interface ports that match the specified administrative status of the switch interface.
[-oper-state {up|down|testing|unknown|dormant|not-present|lower-layer-down}] - Operational Status
Selects the interface ports that match the specified operational status.
[-is-isl {yes|no}] - Is ISL
Selects the interface ports that are Inter-Switch links (yes) or are not Inter-Switch links (no).
[-in-octets <Counter>] - Input Octets
Selects the interface ports that match the specified number of octets entering the interface.
[-in-errors <Counter>] - Input Errors
Selects the interface ports that match the specified number of input packets that were dropped due to errors.
[-in-discards <Counter>] - Input Discards
Selects the interface ports that match the specified number of input packets that were silently discarded (possibly due to buffer overflow).
[-out-octets <Counter>] - Output Octets
Selects the interface ports that match the specified number of octets that exited the interface.
[-out-errors <Counter>] - Output Errors
Selects the interface ports that match the specified number of output packets that were dropped due to errors.
[-out-discards <Counter>] - Output Discards
Selects the interface ports that match the specified number of output packets that were silently discarded (possibly due to buffer overflow).
[-interface-number <integer>] - Interface Number
Selects the interface ports that match the specified interface number.
[-unique-name <text>] - Interface Unique Name
Selects the interface port that matches the specified unique name.
[-display-name <text>] - Interface Display Name
Selects the interface ports that match the specified display name.
[-status {ok|ok-with-suppressed|degraded|unreachable|unknown}] - Port Config Status
Selects the interface ports that match the specified status.
[-monitor {node-connect|system-connect|system|controller|chassis|cluster-switch|example|ethernet-switch}] - Health Monitor
Selects the interface ports that the specified health monitor continuously monitors.
[-switch-type {cluster-network|management-network|storage-network}] - Switch Network
Selects the interface ports that match the specified switch type.
[-remote-port-mtu <integer>,…​] - MTU of Remote Port
Selects the interface ports that match the specified remote port mtu.
[-remote-port-name <text>] - Remote Port Name
Selects the interface ports that match the specified remote port name.
[-remote-device <text>] - Remote Device Name
Selects the interface ports that match the specified remote device.
[-model <text>] - Switch Model
Selects the interface ports that match the specified model.
[-mac-address <text>] - MAC Address
Selects the interface ports that match the specified mac address.
[-vlan-id <text>] - Vlan ID
Selects the interface ports that match the specified vlan id.
cluster1::> system switch ethernet interface show
Switch: SwitchA
Opera-
           Num-                     Admin   tional   Is
Interface  ber  Index     Type      Status  Status   ISL  MTU   Duplex Speed
Ethernet1/    1 436207616 ethernetC up      up       no    1500 full-     40000
1                         smacd                                 duplex
Ethernet1/   10 436244480 ethernetC up      down     no    1500 full-     40000
10                        smacd                                 duplex
Switch: SwitchB
Opera-
1                         smacd                                 duplex
10                        smacd                                 duplex
The example above displays the interfaces on all Ethernet switches (cluster, management and storage).
cluster1::> system switch ethernet interface show -counters
Switch: SwitchA
In                   Out         Out
Interface       In Octets In Errors Discards   Out Octets   Errors    Discards
Ethernet1/1    1856922869    177091        0   3122212606        0           2
Ethernet1/     3242386021         0        0   1408092011        0          74
10
Switch: SwitchB
In                   Out         Out
Ethernet1/1    1281177979    182012        0   3271353786        0           1
Ethernet1/     3611218526         0        0   2626671058        0           0
10
The example above displays the counters on switch network interfaces for all the Ethernet switches (cluster, management and storage).
