security anti-ransomware volume workload-behavior clear-surge
Clear the observed surge values on a volume
The security anti-ransomware volume workload-behavior clear-surge command clears the observed surge values.
-vserver <vserver name>- Vserver Name-
This parameter specifies the Vserver on which the volume is located.
-volume <volume name>- Volume Name-
This parameter specifies the name of the volume on which anti-ransomware feature is enabled.
cluster1::> security anti-ransomware volume workload-behavior show -vserver vs1 -volume vol1
Vserver: vs1
Volume: vol1
File Extensions Observed: .txt, .exe, .pdf, .img
Number of File Extensions Observed: 4
Historical Statistics
High Entropy Data Write Percentage: 50
High Entropy Data Write Peak Rate (KB/Minute): 50
File Create Peak Rate (per Minute): 100
File Delete Peak Rate (per Minute): 100
File Rename Peak Rate (per Minute): 100
Surge Observed
Surge Timeline: 09/05/2022 14:01:00
High Entropy Data Write Percentage: 100
High Entropy Data Write Peak Rate (KB/Minute): 2000
File Create Peak Rate (per Minute): 80
File Delete Peak Rate (per Minute): -
File Rename Peak Rate (per Minute): 200
Newly Observed File Extensions: .dll, .exec, .js
Number of Newly Observed File Extensions: 10, 4, 22
cluster1::> security anti-ransomware volume workload-behavior clear-surge -vserver vs1 -volume vol1
Vserver: vs1
Volume: vol1
Surge Observed
Surge Timeline: -
High Entropy Data Write Percentage: -
High Entropy Data Write Peak Rate (KB/Minute): -
File Create Peak Rate (per Minute): -
File Rename Peak Rate (per Minute): -
