vserver iscsi isns show
Show iSNS service configuration
Shows the iSNS service configuration.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]- Vserver Name-
Use this parameter to display the iSNS services that match the Vserver name that you specify.
[-address <IP Address>]- iSNS Server IP Address-
Use this parameter to display the iSNS services that match the IP address of the iSNS server that you specify.
[-status-admin {down|up}]- Administrative Status-
Use this parameter to display the iSNS services that match the configured status of the service that you specify.
[-entity-id <text>]- iSNS Server Entity Id-
Use this parameter to display the iSNS services that match the configured iSNS server entity-id that you specify.
[-last-successful-update <MM/DD/YYYY HH:MM:SS>]- Last Successful Update-
Use this parameter to display the iSNS services that match the time of the last successful attempt.
[-last-update-attempt <MM/DD/YYYY HH:MM:SS>]- Last Update Attempt-
Use this parameter to display the iSNS services that match the time of the last update attempt.
[-last-update-result <isnsErrors>]- Last Update Result-
Use this parameter to display the iSNS services that match the result of the last update attempt.
cluster1::> vserver iscsi isns show Vserver iSNS Server Entity Identifier iSNS Server IP Address iSNS Status ---------- ------------------------------- ---------------------- ----------- iscsi_vs isns:00000044 10.229.136.188 up
Displays the output of the show command for all Vservers in a cluster.
cluster1::> vserver iscsi isns show -instance
Vserver Name: vs1
iSNS Server IP Address: 10.72.19.11
Administrative Status: up
iSNS Server Entity Id: isns.0000001c
Last Successful Update: 11/12/2011 10:18:45
Last Update Attempt: 11/12/2011 10:18:45
Last Update Result: iSNS_Ok
Vserver Name: vs2
iSNS Server IP Address: 10.72.16.13
iSNS Server Entity Id: isns.0000001b
Last Successful Update: 11/12/2011 13:38:05
Last Update Attempt: 11/12/2011 13:38:05
2 entries were displayed.
Displays the details for all Vservers in a cluster.
