vserver iscsi isns show
Show iSNS service configuration
Shows the iSNS service configuration.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-vserver <Vserver Name>]- Vserver Name
Use this parameter to display the iSNS services that match the Vserver name that you specify.
- [-address <IP Address>]- iSNS Server IP Address
Use this parameter to display the iSNS services that match the IP address of the iSNS server that you specify.
- [-status-admin {down|up}]- Administrative Status
Use this parameter to display the iSNS services that match the configured status of the service that you specify.
- [-entity-id <text>]- iSNS Server Entity Id
Use this parameter to display the iSNS services that match the configured iSNS server entity-id that you specify.
- [-last-successful-update <MM/DD/YYYY HH:MM:SS>]- Last Successful Update
Use this parameter to display the iSNS services that match the time of the last successful attempt.
- [-last-update-attempt <MM/DD/YYYY HH:MM:SS>]- Last Update Attempt
Use this parameter to display the iSNS services that match the time of the last update attempt.
- [-last-update-result <isnsErrors>]- Last Update Result
Use this parameter to display the iSNS services that match the result of the last update attempt.
cluster1::> vserver iscsi isns show Vserver iSNS Server Entity Identifier iSNS Server IP Address iSNS Status ---------- ------------------------------- ---------------------- ----------- iscsi_vs isns:00000044 10.229.136.188 up
Displays the output of the show command for all Vservers in a cluster.
cluster1::> vserver iscsi isns show -instance
          Vserver Name: vs1
iSNS Server IP Address: 10.72.19.11
 Administrative Status: up
 iSNS Server Entity Id: isns.0000001c
Last Successful Update: 11/12/2011 10:18:45
   Last Update Attempt: 11/12/2011 10:18:45
    Last Update Result: iSNS_Ok
Vserver Name: vs2
iSNS Server IP Address: 10.72.16.13
 iSNS Server Entity Id: isns.0000001b
Last Successful Update: 11/12/2011 13:38:05
   Last Update Attempt: 11/12/2011 13:38:05
2 entries were displayed.
Displays the details for all Vservers in a cluster.
 PDFs
PDFs
