security login role config reset
Reset RBAC characteristics supported on releases later than Data ONTAP 8.1.2
The security login role config reset command resets the following role based access control (RBAC) characteristics to their default values. The system prompts you to run this command if you revert to ONTAP 8.1.2 or earlier. If you do not reset these characteristics, the revert process will fail.
Minimum number of special characters required in password ("0")
Minimum number of uppercase characters required in password ("0")
Minimum number of lowercase characters required in password ("0")
Minimum number of digits required in password ("0")
Password-expiration time, in days ("unlimited")
Whether the password must be changed at the initial login ("disabled")
Maximum number of failed login attempts permitted before the account is locked out ("5")
Maximum time period for which the user account is locked out after the maximum number of failed login attempts is reached ("1 Hour")
The following command resets the above mentioned RBAC characteristics of all cluster and Vserver roles to their default values.
cluster1::> security login role config reset
