volume analytics initialization pause
Pause the analytics file system scan
The volume analytics initialization pause
command pauses the file system analytics scan.
-vserver <vserver name>
- Vserver Name-
This specifies the Vserver in which the volume is located.
-volume <volume name>
- Volume Name-
This specifies the name of the volume on which file system analytics initialization is being paused.
The following example pauses the file system analytics scan on a volume named "vol1" in Vserver "vs1":
cluster::*> volume analytics initialization pause -vserver vs1 -volume vol1
