      volume analytics initialization pause
Pause the analytics file system scan
The volume analytics initialization pause command pauses the file system analytics scan.
- -vserver <vserver name>- Vserver Name
This specifies the Vserver in which the volume is located.
- -volume <volume name>- Volume Name
This specifies the name of the volume on which file system analytics initialization is being paused.
The following example pauses the file system analytics scan on a volume named "vol1" in Vserver "vs1":
cluster::*> volume analytics initialization pause -vserver vs1 -volume vol1
 PDFs
PDFs
