Command reference
vserver nfs credentials count
Count credentials cached by NFS
The vserver nfs credentials count command displays the number of credentials stored in NFS credentials cache on a specific node. This command has no effect if the specified node has no active data.
-node <nodename> - Node (privilege: advanced)
The name of the node on which the command is executed.
Lists the number of credentials stored by NFS on node node1
cluster1::*> vserver nfs credentials count -node node1
Number of credentials cached by NFS on node "node1": "2"
