lun mapping show
Lists the mappings between LUNs and initiator groups.
This command lists the mappings between LUNs and initiator groups.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]- Vserver Name-
Selects the LUN maps for the Vserver that matches the parameter value.
[-path <path>]- LUN Path -
Selects the LUN maps for the LUN with the path that matches the parameter value. Examples of correct LUN paths:
/vol/vol1/lun1and/vol/vol1/qtree1/lun1 - |
[-volume <volume name>]- Volume Name -
Selects the LUN maps for the volumes that match the parameter value.
[-qtree <qtree name>]- Qtree Name-
Selects the LUN maps for the queue trees that match the parameter value.
[-lun <text>]- LUN Name }-
Selects the LUN maps for the LUNs with a name that matches the parameter value.
[-g, -igroup <text>]- Igroup Name-
Selects the LUN maps for the igroup that matches the parameter value.
[-ostype <Initiator Group OS Type>]- Igroup OS Type-
Selects the LUN maps for the initiator groups with the OS type that matches the parameter value.
[-protocol <protocol_enum>]- Igroup Protocol Type-
Selects the LUN maps for initiator groups with a protocol that matches the parameter value. Possible values include FCP, iSCSI, or mixed.
[-lun-id <integer>]- LUN ID-
Selects the LUN maps with a LUN ID that matches the parameter value.
[-portset <text>]- Portset Binding Igroup-
Selects the LUN maps for initiator groups bound to the portset that matches the parameter value.
[-alua {true|false}]- ALUA-
Selects the LUN maps with ALUA settings that match the parameter value.
[-n, -initiators <text>,…]- Initiators-
Selects the LUN maps for initiator groups containing the initiators that match the parameter value.
[-node <nodename>]- LUN Node-
Selects the LUN maps for nodes that match the parameter value.
[-reporting-nodes <nodename>,…]- Reporting Nodes-
Selects the LUN maps that match the parameter value.
[-replicated {true|false}]- Replicated-
Selects the LUN maps that match the parameter value. By default, LUN maps are replicated when the initiator group is replicated and the mapped LUN is a member of a SnapMirror Synchronous relationship. When set to
false, the LUN map is not replicated even when these conditions are met. This field is reported as unset when these conditions are not met.
Displays all of the mappings between LUNs and initiator groups and the LUN ID for each mapping.
cluster1::> lun mapping show Vserver Path Igroup LUN ID Protocol ---------- ---------------------------------------- ------- ------ -------- vs1 /vol/vol1/lun1 igroup1 10 mixed vs1 /vol/vol1/lun1 igroup2 4 mixed vs1 /vol/vol5/lun1 igroup3 6 mixed vs1 /vol/vol5/lun2 igroup3 1 mixed 4 entries were displayed.
