lun mapping show
Lists the mappings between LUNs and initiator groups.
This command lists the mappings between LUNs and initiator groups.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]- Vserver Name-
Selects the LUN maps for the Vserver that matches the parameter value.
[-path <path>]- LUN Path -
Selects the LUN maps for the LUN with the path that matches the parameter value. Examples of correct LUN paths are
/vol/vol1/lun1and/vol/vol1/qtree1/lun1. - |
[-volume <volume name>]- Volume Name -
Selects the LUN maps for the volumes that match the parameter value.
[-qtree <qtree name>]- Qtree Name-
Selects the LUN maps for the queue trees that match the parameter value.
[-lun <text>]- LUN Name }-
Selects the LUN maps for the LUNs with a name that matches the parameter value.
[-g, -igroup <text>]- Igroup Name-
Selects the LUN maps for the igroup that matches the parameter value.
[-ostype <Initiator Group OS Type>]- Igroup OS Type-
Selects the LUN maps for the initiator groups with the OS type that matches the parameter value.
[-protocol <protocol_enum>]- Igroup Protocol Type-
Selects the LUN maps for initiator groups with a protocol that matches the parameter value. Possible values include FCP, iSCSI, or mixed.
[-lun-id <integer>]- LUN ID-
Selects the LUN maps with a LUN ID that matches the parameter value.
[-portset <text>]- Portset Binding Igroup-
Selects the LUN maps for initiator groups bound to the portset that matches the parameter value.
[-alua {true|false}]- ALUA-
Selects the LUN maps with ALUA settings that match the parameter value.
[-n, -initiators <text>,…]- Initiators-
Selects the LUN maps for initiator groups containing the initiators that match the parameter value.
[-node <nodename>]- LUN Node-
Selects the LUN maps for nodes that match the parameter value.
[-reporting-nodes <nodename>,…]- Reporting Nodes-
Selects the LUN maps that match the parameter value.
cluster1::> lun mapping show Vserver Path Igroup LUN ID Protocol ---------- ---------------------------------------- ------- ------ -------- vs1 /vol/vol1/lun1 igroup1 10 mixed vs1 /vol/vol1/lun1 igroup2 4 mixed vs1 /vol/vol5/lun1 igroup3 6 mixed vs1 /vol/vol5/lun2 igroup3 1 mixed 4 entries were displayed.
The example above lists all of the mappings between LUNs and initiator groups and the LUN ID for each mapping.
