Command reference
lun mapping show
Lists the mappings between LUNs and initiator groups.
This command lists the mappings between LUNs and initiator groups.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <Vserver Name>] - Vserver Name
Selects the LUN maps for the Vserver that matches the parameter value.
{ [-path <path>] - LUN Path
Selects the LUN maps for the LUN with the path that matches the parameter value. Examples of correct LUN paths: /vol/vol1/lun1 and /vol/vol1/qtree1/lun1
| [-volume <volume name>] - Volume Name
Selects the LUN maps for the volumes that match the parameter value.
[-qtree <qtree name>] - Qtree Name
Selects the LUN maps for the queue trees that match the parameter value.
[-lun <text>] - LUN Name }
Selects the LUN maps for the LUNs with a name that matches the parameter value.
[-g, -igroup <text>] - Igroup Name
Selects the LUN maps for the igroup that matches the parameter value.
[-ostype <Initiator Group OS Type>] - Igroup OS Type
Selects the LUN maps for the initiator groups with the OS type that matches the parameter value.
[-protocol <protocol_enum>] - Igroup Protocol Type
Selects the LUN maps for initiator groups with a protocol that matches the parameter value. Possible values include FCP, iSCSI, or mixed.
[-lun-id <integer>] - LUN ID
Selects the LUN maps with a LUN ID that matches the parameter value.
[-portset <text>] - Portset Binding Igroup
Selects the LUN maps for initiator groups bound to the portset that matches the parameter value.
[-alua {true|false}] - ALUA
Selects the LUN maps with ALUA settings that match the parameter value.
[-n, -initiators <text>,…​] - Initiators
Selects the LUN maps for initiator groups containing the initiators that match the parameter value.
[-node <nodename>] - LUN Node
Selects the LUN maps for nodes that match the parameter value.
[-reporting-nodes <nodename>,…​] - Reporting Nodes
Selects the LUN maps that match the parameter value.
Displays all of the mappings between LUNs and initiator groups and the LUN ID for each mapping.
cluster1::> lun mapping show
Vserver    Path                                      Igroup   LUN ID  Protocol
vs1        /vol/vol1/lun1                            igroup1      10  mixed
vs1        /vol/vol1/lun1                            igroup2       4  mixed
vs1        /vol/vol5/lun1                            igroup3       6  mixed
vs1        /vol/vol5/lun2                            igroup3       1  mixed
4 entries were displayed.
