security webauthn supported-algorithms show
Show WebAuthn Supported Algorithms
The security webauthn supported-algorithms show displays information on the FIDO2/WebAuthn supported algorithms.
[-fields <fieldname>,…] -
Selects the fields that you specify.
[-instance ]} -
Displays all the fields for the FIDO2/WebAuthn supported algorithms.
[-vserver <vserver name>]- Vserver-
Selects the FIDO2/WebAuthn settings that match this parameter value. If not specified, all cluster-level and Vserver-level settings are displayed.
[-alg-name <text>]- Algorithm Name-
[-alg-id <integer>]- Algorithm ID-
[-alg-type <public-key>]- Algorithm Type-
[-scope {svm|cluster}]- Cluster or SVM-
The example below displays information on the FIDO2/WebAuthn supported algorithms:
cluster1::> security webauthn supported-algorithms show
Vserver: cluster1
ID Name Type
-7 ES-256 public-key
-35 ES-384 public-key
-257 RS-256 public-key
3 entries were displayed.
