network connections listening show
Show the listening connections in this cluster
The network connections listening show command displays information about network connections that are in an open and listening state.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
Selects the listening connections that match this parameter value.
[-mgmt-cid <integer>]- Management Connection ID-
[-vserver <vserver>]- Vserver-
[-cid <integer>]- System Connection ID-
[-lif-name <lif-name>]- Logical Interface Name-
[-local-address <IP Address>]- Local IP Address-
[-local-port <integer>]- Local Port-
[-remote-ip <InetAddress>]- Remote IP Address-
[-remote-host <Remote IP>]- Remote Host-
[-remote-port <integer>]- Remote Port-
[-proto {UDP|TCP|TLS|RDMA}]- Protocol-
Selects the listening connections that match this parameter value. Possible values include tcp (TCP), udp (UDP), and NA (not applicable).
[-lifid <integer>]- Logical Interface ID-
[-service <protocol service>]- Protocol Service-
Selects the listening connections that match this parameter value. Possible values include: nfs, iscsi, and loopback.
[-lru {yes|no}]- Least Recently Used-
The following example displays information about all listening network connections:
cluster1::> network connections listening show Vserver Name Interface Name:Local Port Protocol/Service ------------ -------------------------- ----------------- node0 cluslif1:7700 UDP/rclopcp node0 cluslif2:7700 UDP/rclopcp node1 cluslif1:7700 UDP/rclopcp node1 cluslif2:7700 UDP/rclopcp node2 cluslif1:7700 UDP/rclopcp node2 cluslif2:7700 UDP/rclopcp node3 cluslif1:7700 UDP/rclopcp node3 cluslif2:7700 UDP/rclopcp 8 entries were displayed.
The following example displays detailed information about listening network connections for the node named node0:
cluster1::> network connections listening show -node node0
Node: node0
Management Connection Id: 0
System Connection Id: 0
Vserver: vs0
Logical Interface Name: datalif1
Local IP address: 192.0.2.130
Local Port: 111
Remote IP address:
Remote Port: 0
Protocol: UDP
Logical Interface Id: 1029
Protocol Service: port_map
least recently used: yes
Node: node0
Management Connection Id: 1
Server: vs0
Logical Interface Name: datalif2
Local IP address: 192.0.2.131
Local Port: 111
Remote IP address:
Remote Port: 0
Protocol: UDP
Logical Interface Id: 1030
