network connections listening show
Show the listening connections in this cluster
The network connections listening show
command displays information about network connections that are in an open and listening state.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
Selects the listening connections that match this parameter value.
[-mgmt-cid <integer>]
- Management Connection ID-
[-vserver <vserver>]
- Vserver-
[-cid <integer>]
- System Connection ID-
[-lif-name <lif-name>]
- Logical Interface Name-
[-local-address <IP Address>]
- Local IP Address-
[-local-port <integer>]
- Local Port-
[-remote-ip <InetAddress>]
- Remote IP Address-
[-remote-host <Remote IP>]
- Remote Host-
[-remote-port <integer>]
- Remote Port-
[-proto {UDP|TCP}]
- Protocol-
Selects the listening connections that match this parameter value. Possible values include tcp (TCP), udp (UDP), and NA (not applicable).
[-lifid <integer>]
- Logical Interface ID-
[-service <protocol service>]
- Protocol Service-
Selects the listening connections that match this parameter value. Possible values include: nfs, iscsi, and loopback.
[-lru {yes|no}]
- Least Recently Used-
The following example displays information about all listening network connections:
cluster1::> network connections listening show Vserver Name Interface Name:Local Port Protocol/Service ------------ -------------------------- ----------------- node0 cluslif1:7700 UDP/rclopcp node0 cluslif2:7700 UDP/rclopcp node1 cluslif1:7700 UDP/rclopcp node1 cluslif2:7700 UDP/rclopcp node2 cluslif1:7700 UDP/rclopcp node2 cluslif2:7700 UDP/rclopcp node3 cluslif1:7700 UDP/rclopcp node3 cluslif2:7700 UDP/rclopcp 8 entries were displayed.
The following example displays detailed information about listening network connections for the node named node0:
cluster1::> network connections listening show -node node0 Node: node0 Management Connection Id: 0 System Connection Id: 0 Vserver: vs0 Logical Interface Name: datalif1 Local IP address: 192.0.2.130 Local Port: 111 Remote IP address: Remote Port: 0 Protocol: UDP Logical Interface Id: 1029 Protocol Service: port_map least recently used: yes Node: node0 Management Connection Id: 1 System Connection Id: 0 Server: vs0 Logical Interface Name: datalif2 Local IP address: 192.0.2.131 Local Port: 111 Remote IP address: Remote Port: 0 Protocol: UDP Logical Interface Id: 1030 Protocol Service: port_map least recently used: yes
