network connections listening show
Show the listening connections in this cluster
The network connections listening show command displays information about network connections that are in an open and listening state.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-node {<nodename>|local}]- Node
Selects the listening connections that match this parameter value.
- [-mgmt-cid <integer>]- Management Connection ID
- [-vserver <vserver>]- Vserver
- [-cid <integer>]- System Connection ID
- [-lif-name <lif-name>]- Logical Interface Name
- [-local-address <IP Address>]- Local IP Address
- [-local-port <integer>]- Local Port
- [-remote-ip <InetAddress>]- Remote IP Address
- [-remote-host <Remote IP>]- Remote Host
- [-remote-port <integer>]- Remote Port
- [-proto {UDP|TCP}]- Protocol
Selects the listening connections that match this parameter value. Possible values include tcp (TCP), udp (UDP), and NA (not applicable).
- [-lifid <integer>]- Logical Interface ID
- [-service <protocol service>]- Protocol Service
Selects the listening connections that match this parameter value. Possible values include: nfs, iscsi, and loopback.
- [-lru {yes|no}]- Least Recently Used
The following example displays information about all listening network connections:
cluster1::> network connections listening show Vserver Name Interface Name:Local Port Protocol/Service ------------ -------------------------- ----------------- node0 cluslif1:7700 UDP/rclopcp node0 cluslif2:7700 UDP/rclopcp node1 cluslif1:7700 UDP/rclopcp node1 cluslif2:7700 UDP/rclopcp node2 cluslif1:7700 UDP/rclopcp node2 cluslif2:7700 UDP/rclopcp node3 cluslif1:7700 UDP/rclopcp node3 cluslif2:7700 UDP/rclopcp 8 entries were displayed.
The following example displays detailed information about listening network connections for the node named node0:
cluster1::> network connections listening show -node node0
          Node: node0
Management Connection Id: 0
  System Connection Id: 0
         Vserver: vs0
 Logical Interface Name: datalif1
    Local IP address: 192.0.2.130
       Local Port: 111
    Remote IP address:
       Remote Port: 0
        Protocol: UDP
  Logical Interface Id: 1029
    Protocol Service: port_map
   least recently used: yes
          Node: node0
Management Connection Id: 1
         Server: vs0
 Logical Interface Name: datalif2
    Local IP address: 192.0.2.131
       Local Port: 111
    Remote IP address:
       Remote Port: 0
        Protocol: UDP
  Logical Interface Id: 1030
 PDFs
PDFs
