network connections listening show
Show the listening connections in this cluster
The network connections listening show command displays information about network connections that are in an open and listening state.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
Selects the listening connections that match this parameter value.
 [-mgmt-cid <integer>]- Management Connection ID-
 [-vserver <vserver>]- Vserver-
 [-cid <integer>]- System Connection ID-
 [-lif-name <lif-name>]- Logical Interface Name-
 [-local-address <IP Address>]- Local IP Address-
 [-local-port <integer>]- Local Port-
 [-remote-ip <InetAddress>]- Remote IP Address-
 [-remote-host <Remote IP>]- Remote Host-
 [-remote-port <integer>]- Remote Port-
 [-proto {UDP|TCP}]- Protocol-
Selects the listening connections that match this parameter value. Possible values include tcp (TCP), udp (UDP), and NA (not applicable).
 [-lifid <integer>]- Logical Interface ID-
 [-service <protocol service>]- Protocol Service-
Selects the listening connections that match this parameter value. Possible values include: nfs, iscsi, and loopback.
 [-lru {yes|no}]- Least Recently Used-
The following example displays information about all listening network connections:
cluster1::> network connections listening show Vserver Name Interface Name:Local Port Protocol/Service ------------ -------------------------- ----------------- node0 cluslif1:7700 UDP/rclopcp node0 cluslif2:7700 UDP/rclopcp node1 cluslif1:7700 UDP/rclopcp node1 cluslif2:7700 UDP/rclopcp node2 cluslif1:7700 UDP/rclopcp node2 cluslif2:7700 UDP/rclopcp node3 cluslif1:7700 UDP/rclopcp node3 cluslif2:7700 UDP/rclopcp 8 entries were displayed.
The following example displays detailed information about listening network connections for the node named node0:
cluster1::> network connections listening show -node node0
          Node: node0
Management Connection Id: 0
  System Connection Id: 0
         Vserver: vs0
 Logical Interface Name: datalif1
    Local IP address: 192.0.2.130
       Local Port: 111
    Remote IP address:
       Remote Port: 0
        Protocol: UDP
  Logical Interface Id: 1029
    Protocol Service: port_map
   least recently used: yes
          Node: node0
Management Connection Id: 1
         Server: vs0
 Logical Interface Name: datalif2
    Local IP address: 192.0.2.131
       Local Port: 111
    Remote IP address:
       Remote Port: 0
        Protocol: UDP
  Logical Interface Id: 1030
