system controller coredump-device show-serial-number
Display the coredump device serial number
The system controller coredump-device show-serial-number
command displays the serial number of coredump devices. This command is only applicable to AFF A700 systems. By default, the command displays the following information about the coredump device:
Node name
Display name
Serial number
Size
Device state
Status
To display more details, use the -instance
parameter.
[-fields <fieldname>,…]
Selects the fields that you specify.
[-instance ]
Displays detailed information for the coredump device.
[-node {<nodename>|local}]
- Node-
Selects the coredump device that is present on the specified node.
[-serial-num <text>]
- Serial Number-
Selects the coredump device with the specified serial number.
[-vendor-id <Hex Integer>]
- Vendor ID-
Selects the coredump device with the specified vendor ID.
[-device-id <Hex Integer>]
- Device ID-
Selects the coredump device with the specified device ID.
[-display-name <text>]
- Display Name-
Selects the coredump device with the specified display name.
[-unique-name <text>]
- Unique Name-
Selects the coredump device with the specified unique name.
[-monitor {node-connect|system-connect|system|controller|chassis|cluster-switch|example|ethernet-switch}]
- Health Monitor Name-
Selects the coredump device with the specified health monitor.
[-health-status {present|not-present}]
- Health Status-
Selects the coredump device with the specified health status.
[-device-state {good|warn|bad}]
- Device State-
Selects the coredump device with the specified device state.
[-size <integer>]
- Max Memory Size (GB)-
Selects the coredump device with the specified memory size.
[-health {ok|ok-with-suppressed|degraded|unreachable|unknown}]
- Status-
Selects the coredump device with the specified health monitor status.
[-shelf-status {present|not-present}]
- Shelf Connected Status-
Selects the coredump device with the specified shelf connected status.
The following example displays the information of the coredump device present in all the nodes in a cluster:
cluster1::> system controller coredump-device show-serial-number Size Device Node FRU/Display Name Serial Number (GB) State Status ------------- -------------------- ------------------- ------- --------- ------ cluster1-01 Coredump/X9170A A22P5061550000644 1024 good ok cluster1-02 Coredump/X9170A A22P5061550000137 1024 good ok 2 entries were displayed.
The following example displays the detailed information about the coredump device present in a node:
cluster1::> system controller coredump-device show-serial-number -instance -node cluster1-01 Node: cluster1-01 Serial Number: A22P5061550000644 Vendor ID: 1b85 Device ID: 4018 Display Name: Coredump/X9170A Unique Name: 0X91701190020741OCZ000Z63000001T0003500 Health Monitor Name: controller Health Status: present Device State: good Max Memory Size (GB): 1024 Status: ok Shelf Connected Status: present
