system switch ethernet show-all
(DEPRECATED)-Displays the list of switches
This command has been deprecated. It may be removed from a future release of ONTAP. |
The system switch ethernet show-all command displays configuration details for cluster and storage Ethernet switches.
[-fields <fieldname>,…]-
Selects the fields that have the specified name.
[-instance ](privilege: advanced) } -
Selects detailed information for all the switches.
[-device <text>]- Device Name (privilege: advanced)-
Selects the switches that match the specified device name.
[-address <IP Address>]- IP Address (privilege: advanced)-
Selects the switches that match the specified IP address.
[-snmp-version {SNMPv1|SNMPv2c|SNMPv3}]- SNMP Version (privilege: advanced)-
Selects the switches that match the specified SNMP version.
[-community-or-username <text>]- SNMPv2c Community String or SNMPv3 Username (privilege: advanced)-
Selects the switches that match the specified community string or SNMPv3 username.
[-discovered {true|false}]- Is Discovered (privilege: advanced)-
Selects the switches that match the specified discovery setting.
[-type {cluster-network|storage-network}]- Switch Network (privilege: advanced)-
Selects the switches that match the specified switch type.
[-sw-version <text>]- Software Version (privilege: advanced)-
Selects the switches that match the specified software version.
[-is-monitoring-enabled-operational {true|false}]- Switch Monitoring Status (privilege: advanced)-
Selects the switches that match the specified operational monitoring status.
[-reason <text>]- Reason For Not Monitoring (privilege: advanced)-
Selects the switches that match the specified reason.
[-version-source <text>]- Source Of Switch Version (privilege: advanced)-
Selects the switches that match the specified version source (for example, SNMP, CDP, ISDP, or LLDP).
[-rcf-version <text>]- Reference Config File Version (privilege: advanced)-
Selects the switches that match the specified reference configuration file version.
[-serial-number <text>]- Serial Number of the Device (privilege: advanced)-
Selects the switches that match the specified serial number.
[-model <text>]- Model to display (privilege: advanced)-
Selects the switches that match the specified model number.
[-role <text>]- Configured Role (privilege: advanced)-
Selects the switches that match the specified role or combined role (different roles can be combined using '+').
cluster1::> system switch ethernet show-all
Switch Type Address Model
SwitchA cluster 1.2.3.4 Nexus5010
Is Monitored: yes
Reason:
Software Version: Cisco IOS 4.1N1
Version Source: CDP
The example above displays the configuration of all Ethernet switches (cluster and storage).
