ONTAP commands
system switch ethernet show-all
Displays the list of switches that were added and deleted
The system switch ethernet show-all command displays configuration details for discovered monitored Ethernet switches (cluster, management and storage), including switches that are user-deleted. From the list of deleted switches, you can delete a switch permanently from the database to re-enable automatic discovery of that switch.
{ [-fields <fieldname>,…​]
Selects the fields that have the specified name.
| [-instance ] }
Selects detailed information for all the switches.
[-device <text>] - Device Name (privilege: advanced)
Selects the switches that match the specified device name.
[-address <IP Address>] - IP Address (privilege: advanced)
Selects the switches that match the specified IP address.
[-snmp-version {SNMPv1|SNMPv2c|SNMPv3}] - SNMP Version (privilege: advanced)
Selects the switches that match the specified SNMP version.
[-community <text>] - DEPRECATED-Community String or SNMPv3 Username (privilege: advanced)
Note This parameter is deprecated and may be removed in a future release of ONTAP. Use -community-or-username instead.
Selects the switches that match the specified community string or SNMPv3 username.
[-community-or-username <text>] - Community String or SNMPv3 Username (privilege: advanced)
[-discovered {true|false}] - Is Discovered (privilege: advanced)
Selects the switches that match the specified discovery setting.
[-type {cluster-network|management-network|storage-network}] - Switch Network (privilege: advanced)
Selects the switches that match the specified switch type.
[-sw-version <text>] - Software Version (privilege: advanced)
Selects the switches that match the specified software version.
[-is-monitoring-enabled-operational {true|false}] - Switch Monitoring Status (privilege: advanced)
Selects the switches that match the specified operational monitoring status.
[-reason <text>] - Reason For Not Monitoring (privilege: advanced)
Selects the switches that match the specified reason.
[-version-source <text>] - Source Of Switch Version (privilege: advanced)
Selects the switches that match the specified version source (for example, from SNMP, CDP or ISDP).
[-rcf-version <text>] - Reference Config File Version (privilege: advanced)
Selects the switches that match the specified reference configuration file version.
[-serial-number <text>] - Serial Number of the Device (privilege: advanced)
Selects the switches that match the specified serial number.
[-model <text>] - Model to display (privilege: advanced)
Selects the switches that match the specified model number.
cluster1::> system switch ethernet show-all
  Switch                      Type               Address          Model
  SwitchA                     cluster            1.2.3.4          Nexus5010
        Is Monitored: yes
              Reason:
    Software Version: Cisco IOS 4.1N1
      Version Source: CDP
The example above displays the configuration of all Ethernet switches (cluster, management and storage).
