system switch ethernet show-all
PDF of this doc site
Creating your file...
Displays the list of switches that were added and deleted
The system switch ethernet show-all
command displays configuration details for discovered monitored Ethernet switches (cluster, management and storage), including switches that are user-deleted. From the list of deleted switches, you can delete a switch permanently from the database to re-enable automatic discovery of that switch.
[-fields <fieldname>,…]
Selects the fields that have the specified name.
[-instance ]
Selects detailed information for all the switches.
[-device <text>]
- Device Name (privilege: advanced)-
Selects the switches that match the specified device name.
[-address <IP Address>]
- IP Address (privilege: advanced)-
Selects the switches that match the specified IP address.
[-snmp-version {SNMPv1|SNMPv2c|SNMPv3}]
- SNMP Version (privilege: advanced)-
Selects the switches that match the specified SNMP version.
[-community-or-username <text>]
- SNMPv2c Community String or SNMPv3 Username (privilege: advanced)-
Selects the switches that match the specified community string or SNMPv3 username.
[-discovered {true|false}]
- Is Discovered (privilege: advanced)-
Selects the switches that match the specified discovery setting.
[-type {cluster-network|management-network|storage-network}]
- Switch Network (privilege: advanced)-
Selects the switches that match the specified switch type.
[-sw-version <text>]
- Software Version (privilege: advanced)-
Selects the switches that match the specified software version.
[-is-monitoring-enabled-operational {true|false}]
- Switch Monitoring Status (privilege: advanced)-
Selects the switches that match the specified operational monitoring status.
[-reason <text>]
- Reason For Not Monitoring (privilege: advanced)-
Selects the switches that match the specified reason.
[-version-source <text>]
- Source Of Switch Version (privilege: advanced)-
Selects the switches that match the specified version source (for example, from SNMP, CDP or ISDP).
[-rcf-version <text>]
- Reference Config File Version (privilege: advanced)-
Selects the switches that match the specified reference configuration file version.
[-serial-number <text>]
- Serial Number of the Device (privilege: advanced)-
Selects the switches that match the specified serial number.
[-model <text>]
- Model to display (privilege: advanced)-
Selects the switches that match the specified model number.
cluster1::> system switch ethernet show-all Switch Type Address Model --------------------------- ------------------ ---------------- --------------- SwitchA cluster 1.2.3.4 Nexus5010 Is Monitored: yes Reason: Software Version: Cisco IOS 4.1N1 Version Source: CDP
The example above displays the configuration of all Ethernet switches (cluster, management and storage).
