Command reference
storage tape show-supported-status
Displays the qualification and supported status of tape drives
This command displays the supported and qualification status of all tape drives recognized by ONTAP attached to a node in the cluster. This includes nonqualified tape drives. Such tape drives do not have a Tape Configuration File (TCF) on the storage system. A nonqualified tape drive can be used if the tape drive emulates a qualified tape drive or if the appropriate TCF for the nonqualified tape drive is downloaded from the NetApp Support Site to the storage system.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
Selects the tape drives that match this parameter value.
[-tape-drive <text>] - Tape Drive Name
[-is-supported {true|false}] - Tape Drive Supported
[-status <text>] - Supported Status
The following example displays support and qualification status of tape drives recognized by ONTAP. The command also identifies tape drives attached to the node that are nonqualified (not supported).
cluster1::> storage tape show-supported-status
Node: Node1
                               Is
     Tape Drive                Supported  Support Status
     sw4:2.126L6               false      Nonqualified tape drive
     Hewlett-Packard C1533A    true       Qualified
     Hewlett-Packard C1553A    true       Qualified
     Hewlett-Packard Ultrium 1 true       Qualified
     Sony SDX-300C             true       Qualified
     Sony SDX-500C             true       Qualified
     StorageTek T9840C         true       Dynamically Qualified
     StorageTek T9840D         true       Dynamically Qualified
     Tandberg LTO-2 HH         true       Dynamically Qualified
     drives selected by –tape-drive. The command identifies the supported
     status of the selected tape drive.
cluster1::> storage tape show-supported-status -tape-drive "Sony SDX-300C"
Node: Node1
                                  Is
  Tape Drives                     Supported  Support Status
