system health alert definition show
Display system health alert definition
The system health alert definition show command displays information about the various alerts defined in the system health monitor policy file. Using -instance will display additional details.
[-fields <fieldname>,…] -
Selects the fields that you specify.
[-instance ]} -
Use this parameter to display additional information on each alert definition.
Node name
Monitor name
Subsystem identifier
Alert ID
Severity of the alert
Probable cause
Probable cause description
Possible effect due the error state
Recommended corrective actions to be followed
Any additional information
Additional alert tags
[-node {<nodename>|local}]- Node-
Selects the alert definitions for the specified node.
[-monitor <hm_type>]- Monitor-
Selects the alert definitions with the specified monitor name.
[-alert-id <text>]- Class of Alert-
Selects the alert definitions with the specified alert identifier.
[-perceived-severity <hm_perceived_sev>]- Severity of Alert-
Selects the alert definitions with the specified perceived severity.
[-probable-cause <hm_probable_cause>]- Probable Cause-
Selects the alert definitions with the specified probable cause of the alert.
[-probable-cause-description <text>]- Probable Cause Description-
Selects the alert definitions with the specified probable cause description.
[-possible-effect <text>]- Possible Effect-
Selects the alert definitions with the specified possible effect.
[-corrective-actions <text>]- Corrective Actions-
Selects the alert definitions with the specified corrective action.
[-subsystem <hm_subsystem>]- Subsystem Name-
Selects the alert definitions with the specified subsystem.
[-additional-information <text>]- Additional Relevant Data-
Selects the alert definitions with the specified additional information.
[-tags <hm_alert_type>,…]- Additional Alert Tags-
Selects the alert definitions with the specified keywords.
The example below displays information about all the definitions in the alert definition file:
cluster1::> system health alert definition show
Node Monitor Subsystem Alert ID
node-01 system-connect SAS-connect DualControllerNonHa_
Alert
Severity: Major
Probable Cause: Configuration_error
Probable Cause Description: Disk shelf $(sschm_shelf_info.id) is connected to
two controllers
($(sschm_shelf_info.connected-nodes)) that are
not an HA pair.
Possible Effect: Access to disk shelf $(sschm_shelf_info.id) may
be lost with a single controller failure.
Corrective Actions: 1. Halt all controllers that are connected to disk shelf $(sschm_shelf_info.id).
2. Connect disk shelf $(sschm_shelf_info.id) to both HA controllers following the rules in the Universal SAS and ACP Cabling Guide.
3. Reboot the halted controllers.
4. Contact support personnel if the alert persists.
Additional Info: -
Tags: quality_of_service, nondisruptive-upgrade
The example below displays detailed information about the definitions in the alert definition file:
cluster1::> system health alert definition show -instance
Node: krivC-01
Monitor: system-connect
Class of Alert: DualControllerNonHa_Alert
Severity of Alert: Major
Probable Cause Description: Disk shelf $(sschm_shelf_info.id) is connected to two controllers ($(sschm_shelf_info.connected-nodes)) that are not an HA pair.
Possible Effect: Access to disk shelf $(sschm_shelf_info.id) may be lost with a single controller failure.
Subsystem Name: SAS-connect
Additional Relevant Data: -
Additional Alert Tags: quality_of_service, nondisruptive-upgrade
