metrocluster configuration-settings mediator show
Display the nodes connected to the mediator
The metrocluster configuration-settings mediator show command displays the connection status of the nodes with the Mediator in a MetroCluster configuration.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-mediator-address <IP Address>]- Mediator IP Address-
Specifies the IP address of the mediator to which the nodes in the MetroCluster configuration are connected.
[-port <integer>]- Mediator port number-
Specifies the port of the mediator to which the nodes in the MetroCluster configuration are connected.
[-node {<nodename>|local}]- Node Name-
Specifies the nodes in the MetroCluster configuration which are connected to the mediator.
[-reachable {true|false}]- Connection Status of the Mediator-
Specifies the connection status of the nodes with the mediator in the MetroCluster configuration.
[-configured {true|false}]- Mediator Configuration Status-
Specifies the configuration status of the nodes with the mediator in the MetroCluster configuration.
[-type {<iscsi-mediator>|<https-mediator>}]- Mediator Connection Type-
Specifies mediator connection type in the MetroCluster configuration.
The following example shows the mediator type status in a MetroCluster configuration over IP setup:
cluster1_node_01::*> metrocluster configuration-settings mediator show
Mediator IP Port Type Node Configuration Connection
Status Status
10.234.217.168
31784 iscsi-mediator cluster1_node_01 true true
cluster1_node_02 true true
cluster2_node_01 true true
cluster2_node_02 true true
