metrocluster configuration-settings mediator show
Display the nodes connected to the mediator
The metrocluster configuration-settings mediator show
command displays the connection status of the nodes with the Mediator in a MetroCluster configuration.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-mediator-address <IP Address>]
- Mediator IP Address-
Specifies the IP address of the mediator to which the nodes in the MetroCluster configuration are connected.
[-port <integer>]
- Mediator port number-
Specifies the port of the mediator to which the nodes in the MetroCluster configuration are connected.
[-node {<nodename>|local}]
- Node Name-
Specifies the nodes in the MetroCluster configuration which are connected to the mediator.
[-reachable {true|false}]
- Connection Status of the Mediator-
Specifies the connection status of the nodes with the mediator in the MetroCluster configuration.
[-configured {true|false}]
- Mediator Configuration Status-
Specifies the configuration status of the nodes with the mediator in the MetroCluster configuration.
The following example shows the mediator connection status in a MetroCluster configuration over IP setup:
cluster1_node_01::*> metrocluster configuration-settings mediator show Mediator IP Port Node Configuration Connection Status Status --------------- ------- ----------------------- ------------- ----------- 10.234.217.168 31784 cluster1_node_01 true true cluster1_node_02 true true cluster2_node_01 true true cluster2_node_02 true true
