ONTAP commands
metrocluster configuration-settings mediator show
Display the nodes connected to the mediator
The metrocluster configuration-settings mediator show command displays the connection status of the nodes with the Mediator in a MetroCluster configuration.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-mediator-address <IP Address>] - Mediator IP Address
Specifies the IP address of the mediator to which the nodes in the MetroCluster configuration are connected.
[-port <integer>] - Mediator port number
Specifies the port of the mediator to which the nodes in the MetroCluster configuration are connected.
[-node {<nodename>|local}] - Node Name
Specifies the nodes in the MetroCluster configuration which are connected to the mediator.
[-reachable {true|false}] - Connection Status of the Mediator
Specifies the connection status of the nodes with the mediator in the MetroCluster configuration.
[-configured {true|false}] - Mediator Configuration Status
Specifies the configuration status of the nodes with the mediator in the MetroCluster configuration.
The following example shows the mediator connection status in a MetroCluster configuration over IP setup:
cluster1_node_01::*> metrocluster configuration-settings mediator show
        Mediator IP     Port    Node                    Configuration Connection
                                                        Status        Status
        10.234.217.168
                        31784   cluster1_node_01        true          true
                                cluster1_node_02        true          true
                                cluster2_node_01        true          true
                                cluster2_node_02        true          true
