storage iscsi-initiator connect
Connect to an iSCSI target
The storage iscsi-initiator connect command connects a node to the specified target. This command is only supported on high-availability shared-nothing virtualized platforms.
- -node {<nodename>|local}- Node (privilege: advanced)
Specifies the name of the ONTAP node to which the iSCSI target will be connected.
- [-target-type {external|mailbox|partner|partner2|dr_auxiliary|dr_partner}]- Target Type (privilege: advanced)
Selects targets with the specified target type.
- -label <text>- User Defined Identifier (privilege: advanced)
Specifies the label of the target to connect to.
The following example adds and connects to an iSCSI target from the specified node.
cluster1::*> storage iscsi-initiator connect -node node1
             -label target1
 PDFs
PDFs
