The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
storage iscsi-initiator connect
PDF of this doc site
Creating your file...
Your file is ready
Connect to an iSCSI target
The storage iscsi-initiator connect
command connects a node to the specified target. This command is only supported on high-availability shared-nothing virtualized platforms.
-node {<nodename>|local}
- Node (privilege: advanced)-
Specifies the name of the Data ONTAP node to which the iSCSI target will be connected.
[-target-type {external|mailbox|partner|partner2|dr_auxiliary|dr_partner}]
- Target Type (privilege: advanced)-
Selects targets with the specified target type.
-label <text>
- User Defined Identifier (privilege: advanced)-
Specifies the label of the target to connect to.
The following example adds and connects to an iSCSI target from the specified node.
cluster1::*> storage iscsi-initiator connect -node node1 -label target1
