storage iscsi-initiator connect
Connect to an iSCSI target
The storage iscsi-initiator connect
command connects a node to the specified target. This command is only supported on high-availability shared-nothing virtualized platforms.
-node {<nodename>|local}
- Node (privilege: advanced)-
Specifies the name of the Data ONTAP node to which the iSCSI target will be connected.
[-target-type {external|mailbox|partner|partner2|dr_auxiliary|dr_partner}]
- Target Type (privilege: advanced)-
Selects targets with the specified target type.
-label <text>
- User Defined Identifier (privilege: advanced)-
Specifies the label of the target to connect to.
The following example adds and connects to an iSCSI target from the specified node.
cluster1::*> storage iscsi-initiator connect -node node1 -label target1
