ONTAP commands
vserver nvme subsystem host show
Display NVMe hosts configured to the subsystem
The vserver nvme subsystem host show command displays information for the NVMe subsystem hosts.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <Vserver Name>] - Vserver Name
Use this parameter to display the NVMe subsystem hosts that match the Vserver that you specify.
[-subsystem <text>] - Subsystem
Use this parameter to display the NVMe subsystem hosts that match the subsystem that you specify.
[-host-nqn <text>] - Host NQN
Use this parameter to display the NVMe subsystem host that matches the subsystem host NQN that you specify.
[-io-queue-count <integer>] - Number of I/O Queue Pairs
Use this parameter to display the NVMe subsystem hosts that match the maximum IO queue count that you specify.
[-io-queue-depth <integer>] - I/O Queue Depth
Use this parameter to display the NVMe subsystem hosts that match the maxium IO queue depth that you specify.
cluster::*> vserver nvme subsystem host show -vserver vs_1 -subsystem sub_1
Vserver Subsystem Host NQN
vs_1    sub_1     nqn.2001-08.com.example:nvme:host1
                  nqn.2001-08.com.example:nvme:host2
                  nqn.2001-08.com.example:nvme:host3
3 entries were displayed.
