vserver nvme subsystem host show
Display NVMe hosts configured to the subsystem
The vserver nvme subsystem host show command displays information for the NVMe subsystem hosts.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-vserver <Vserver Name>]- Vserver Name
Use this parameter to display the NVMe subsystem hosts that match the Vserver that you specify.
- [-subsystem <text>]- Subsystem
Use this parameter to display the NVMe subsystem hosts that match the subsystem that you specify.
- [-host-nqn <text>]- Host NQN
Use this parameter to display the NVMe subsystem host that matches the subsystem host NQN that you specify.
- [-io-queue-count <integer>]- Number of I/O Queue Pairs
Use this parameter to display the NVMe subsystem hosts that match the maximum IO queue count that you specify.
- [-io-queue-depth <integer>]- I/O Queue Depth
Use this parameter to display the NVMe subsystem hosts that match the maxium IO queue depth that you specify.
cluster::*> vserver nvme subsystem host show -vserver vs_1 -subsystem sub_1
Vserver Subsystem Host NQN
vs_1    sub_1     nqn.2001-08.com.example:nvme:host1
                  nqn.2001-08.com.example:nvme:host2
                  nqn.2001-08.com.example:nvme:host3
3 entries were displayed.
 PDFs
PDFs
