vserver nvme subsystem host show
Display NVMe hosts configured to the subsystem
The vserver nvme subsystem host show command displays information for the NVMe subsystem hosts.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]- Vserver Name-
Use this parameter to display the NVMe subsystem hosts that match the Vserver that you specify.
[-subsystem <text>]- Subsystem-
Use this parameter to display the NVMe subsystem hosts that match the subsystem that you specify.
[-host-nqn <text>]- Host NQN-
Use this parameter to display the NVMe subsystem host that matches the subsystem host NQN that you specify.
[-priority {regular|high}]- Host Priority-
Specifies the host priority.
[-io-queue-count <integer>]- Number of I/O Queue Pairs-
Use this parameter to display the NVMe subsystem hosts that match the maximum IO queue count that you specify.
[-io-queue-depth <integer>]- I/O Queue Depth-
Use this parameter to display the NVMe subsystem hosts that match the maximum IO queue depth that you specify.
[-dhchap-hash-function {sha-256|sha-512}]- Authentication Hash Function-
Specifies the NVMe DH-HMAC-CHAP in-band authentication hash function.
[-dhchap-dh-group {none|2048-bit|3072-bit|4096-bit|6144-bit|8192-bit}]- Authentication Diffie-Hellman Group-
Specifies the NVMe DH-HMAC-CHAP in-band authentication Diffie-Hellman group size.
[-dhchap-mode {none|unidirectional|bidirectional}]- Authentication Mode-
Reports the NVMe DH-HMAC-CHAP in-band authentication mode.
[-tls-key-type {none|configured|generated}]- TLS Key Type-
Specifies the type of TLS pre-shared key (PSK) for the host.
[-proximal-vservers <text>,…]- Proximal Vserver Names-
Select name of Vservers that are configured as proximal to the subsystem host.
cluster::*> vserver nvme subsystem host show -vserver vs_1 -subsystem sub_1
Vserver Subsystem Host NQN
vs_1 sub_1 nqn.2001-08.com.example:nvme:host1
nqn.2001-08.com.example:nvme:host2
nqn.2001-08.com.example:nvme:host3
3 entries were displayed.
