volume clone sharing-by-split undo show
PDF of this doc site
Creating your file...
Show the status of volume clone undo-sharing operations in-progress
The volume clone sharing-by-split undo show
command displays the progress information of undo-sharing in the split volumes with shared physical blocks. This command is only supported for flexible volumes. By default, the command displays the following information:
Vserver name
Volume name
Total number of blocks scanned for undo sharing
Total number of blocks present
Percentage of blocks processed
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]
- Vserver Name (privilege: advanced)-
This parameter selects information about the ongoing undo-sharing scan for all volumes on this Vserver.
[-volume <volume name>]
- Volume Name (privilege: advanced)-
This parameter selects information about the ongoing undo-sharing scan on this volume.
[-blocks-scanned <integer>]
- Scanned Blocks (privilege: advanced)-
This parameter selects information about the total number of blocks scanned by undo-sharing in the given volume.
[-blocks-total <integer>]
- Total Blocks (privilege: advanced)-
This parameter selects information about the total number of blocks for the undo-sharing to scan in the given volume.
[-blocks-percentage-complete <integer>]
- Blocks Percentage Complete (privilege: advanced)-
This parameter selects information about the percentage of block processing completed by undo-sharing in the given volume.
The following example displays information about all the ongoing undo-sharing scan in the cluster:
cluster1::> volume clone sharing-by-split undo show Blocks Blocks Blocks Vserver Volume Scanned Total % Complete --------- ------------- ---------- ---------- ----------- vs1 vol_clone1 0 1260 0
The following example displays information about volume vol_clone1
residing on vserver vs1
cluster1::> volume clone sharing-by-split undo show -vserver vs1 -volume vol_clone1 -instance Vserver Name: vs1 Volume Name: vol_clone1 Blocks Scanned: 0 Blocks Total: 1260 Block Percentage complete: 0
