volume clone sharing-by-split undo show
Show the status of volume clone undo-sharing operations in-progress
The volume clone sharing-by-split undo show command displays the progress information of undo-sharing in the split volumes with shared physical blocks. This command is only supported for flexible volumes. By default, the command displays the following information:
Vserver name
Volume name
Total number of blocks scanned for undo sharing
Total number of blocks present
Percentage of blocks processed
[-fields <fieldname>,…]-
If you specify the
[-instance ](privilege: advanced) } -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]- Vserver Name (privilege: advanced)-
This parameter selects information about the ongoing undo-sharing scan for all volumes on this Vserver.
[-volume <volume name>]- Volume Name (privilege: advanced)-
This parameter selects information about the ongoing undo-sharing scan on this volume.
[-blocks-scanned <integer>]- Scanned Blocks (privilege: advanced)-
This parameter selects information about the total number of blocks scanned by undo-sharing in the given volume.
[-blocks-total <integer>]- Total Blocks (privilege: advanced)-
This parameter selects information about the total number of blocks for the undo-sharing to scan in the given volume.
[-blocks-percentage-complete <integer>]- Blocks Percentage Complete (privilege: advanced)-
This parameter selects information about the percentage of block processing completed by undo-sharing in the given volume.
The following example displays information about all the ongoing undo-sharing scan in the cluster:
cluster1::> volume clone sharing-by-split undo show
Blocks Blocks Blocks
Vserver Volume Scanned Total % Complete
vs1 vol_clone1 0 1260 0
The following example displays information about volume vol_clone1 residing on vserver vs1 :
cluster1::> volume clone sharing-by-split undo show -vserver vs1 -volume vol_clone1 -instance
Vserver Name: vs1
Volume Name: vol_clone1
Blocks Scanned: 0
Blocks Total: 1260
Block Percentage complete: 0
