vserver nvme modify
Modify NVMe service configuration
The vserver nvme modify command modifies an NVMe service configuration on a Vserver.
-vserver <Vserver Name>- Vserver Name-
Specifies the Vserver for the NVMe service.
 [-status-admin {down|up}]- Administrative Status-
Specifies the configured administrative status of a service. If you set this parameter to
down, the Vserver will not serve NVMe traffic. [-mdns-service-discovery-enabled {true|false}]- Use Multicast DNS Service Discovery (privilege: advanced)-
Specifies the configured mDNS service discovery status of a service. If you set this parameter to
false, the Vserver will not advertise NVMe-IP LIFs over Multicast DNS. The default value for create istrue.
cluster1::*> vserver nvme modify -vserver vs_1 -status-admin down
Sets the administrative status of the NVMe service on Vserver vs_1 to down .
