vserver nvme modify
Modify NVMe service configuration
The vserver nvme modify command modifies an NVMe service configuration on a Vserver.
-vserver <Vserver Name> - Vserver Name
Specifies the Vserver for the NVMe service.
[-status-admin {down|up}] - Administrative Status
Specifies the configured administrative status of a service. If you set this parameter to down , the Vserver will not serve NVMe traffic.
cluster1::*> vserver nvme modify -vserver vs_1 -status-admin down
Sets the adminitrative status of the NVMe service on Vserver vs_1 to down .
