cluster controller-replacement network displaced-vlans show
Display VLANs displaced by controller-replacement
Display VLAN tags that were displaced due to a controller-replacement. A VLAN tag that has been displaced is a tag that was based on a network port that either no longer exists, or was moved to a new broadcast domain. Restoring the vlan-tags re-creates them on the specified network port.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node <nodename>]- Node-
Selects the node on which the displaced vlans reside.
[-port <netport>]- Original Base Port-
The original base port where the vlans existed prior to controller-replacement.
[-vlan-tags <integer>,…]- Displaced VLANs-
The vlan-tags that were assigned to the network port prior to controller-replacement.
The following example displays the displaced vlan-tag information.
cluster1::> cluster controller-replacement network displaced-vlans show cluster controller-replacement network displaced-vlans show) riginal ode Base Port VLANs -------- --------- --------------------------------------------------------- ode1 e0c 100,110,120,300,310,320 1 entry was displayed.
