cluster controller-replacement network displaced-vlans show
Display VLANs displaced by controller-replacement
Display VLAN tags that were displaced due to a controller-replacement. A VLAN tag that has been displaced is a tag that was based on a network port that either no longer exists, or was moved to a new broadcast domain. Restoring the vlan-tags re-creates them on the specified network port.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node <nodename>]
- Node-
Selects the node on which the displaced vlans reside.
[-port <netport>]
- Original Base Port-
The original base port where the vlans existed prior to controller-replacement.
[-vlan-tags <integer>,…]
- Displaced VLANs-
The vlan-tags that were assigned to the network port prior to controller-replacement.
The following example displays the displaced vlan-tag information.
cluster1::> cluster controller-replacement network displaced-vlans show cluster controller-replacement network displaced-vlans show) riginal ode Base Port VLANs -------- --------- --------------------------------------------------------- ode1 e0c 100,110,120,300,310,320 1 entry was displayed.
