ONTAP commands
cluster controller-replacement network displaced-vlans show
Display VLANs displaced by controller-replacement
Display VLAN tags that were displaced due to a controller-replacement. A VLAN tag that has been displaced is a tag that was based on a network port that either no longer exists, or was moved to a new broadcast domain. Restoring the vlan-tags re-creates them on the specified network port.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node <nodename>] - Node
Selects the node on which the displaced vlans reside.
[-port <netport>] - Original Base Port
The original base port where the vlans existed prior to controller-replacement.
[-vlan-tags <integer>,…​] - Displaced VLANs
The vlan-tags that were assigned to the network port prior to controller-replacement.
The following example displays the displaced vlan-tag information.
cluster1::> cluster controller-replacement network displaced-vlans show
cluster controller-replacement network displaced-vlans show)
riginal
ode      Base Port VLANs
ode1     e0c       100,110,120,300,310,320
1 entry was displayed.
