cluster controller-replacement network displaced-vlans show
Display VLANs displaced by controller-replacement
Display VLAN tags that were displaced due to a controller-replacement. A VLAN tag that has been displaced is a tag that was based on a network port that either no longer exists, or was moved to a new broadcast domain. Restoring the vlan-tags re-creates them on the specified network port.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-node <nodename>]- Node
Selects the node on which the displaced vlans reside.
- [-port <netport>]- Original Base Port
The original base port where the vlans existed prior to controller-replacement.
- [-vlan-tags <integer>,…]- Displaced VLANs
The vlan-tags that were assigned to the network port prior to controller-replacement.
The following example displays the displaced vlan-tag information.
cluster1::> cluster controller-replacement network displaced-vlans show cluster controller-replacement network displaced-vlans show) riginal ode Base Port VLANs -------- --------- --------------------------------------------------------- ode1 e0c 100,110,120,300,310,320 1 entry was displayed.
 PDFs
PDFs
