vserver nfs connected-clients show
Display List of recent NFS clients information
The `nfs connected-clients show ` command displays information about currently connected NFS clients, other NFS clients that are are currently idle but can be connected, and a list of recently unmounted clients. If a client connected to the NFS server is idle for longer than the maximum cache idle time, then the entry will be removed. By default, the maximum cache idle time is 48 hours.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node Name
Use this parameter to display information only about the specified node.
[-vserver <vserver>] - Vserver
Use this parameter to display information only about the specified vserver.
[-data-lif-ip <IP Address>] - Data LIF IP Address
Use this parameter to display information only about the specified data LIF IP.
[-client-ip <IP Address>] - Client IP Address
Use this parameter to display information only about the specified client IP.
[-volume <volume name>] - Volume Accessed
Use this parameter to display information only about the specified volume.
[-protocol <Client Access Protocol>] - Protocol Version
Use this parameter to display information only about the specified protocol.
[-idle-time <[<integer>d][<integer>h][<integer>m][<integer>s]>] - Idle Time (Sec)
Use this parameter to display the time elapsed since the client sent the last request for this volume.
[-local-reqs <integer>] - Number of Local Reqs
Use this parameter to display a counter tracking requests that are sent to the volume with fast-path.
[-remote-reqs <integer>] - Number of Remote Reqs
Use this parameter to display a counter tracking requests that are sent to the volume with slow-path to remote Dblade using a CSM session.
[-policy-name <text>] - Export Policy Name
Use this parameter to display the Policy Name for this volume.
[-trunking-status {true|false}] - Trunking Status
Use this parameter to display trunking status for the specified client/connection.
The following example displays the connected clients information.
cluster-1::*> nfs connected-clients show
Node: vsim1
  Vserver: vs1
  Data-Ip: 10.140.72.214
Client-Ip      Protocol Volume    Policy   Idle-Time    Local-Reqs Remote-Reqs
10.140.137.57  nfs4     rvol1     pol1     5s           9          0
10.140.137.57  nfs3     vol1      pol1     6m 51s       14         0
10.140.137.57  nfs4     vol1      pol1     5s           16         0
3 entries were displayed.
