vserver nfs connected-clients show
Display List of recent NFS clients information
The `nfs connected-clients show ` command displays information about currently connected NFS clients, other NFS clients that are are currently idle but can be connected, and a list of recently unmounted clients. If a client connected to the NFS server is idle for longer than the maximum cache idle time, then the entry will be removed. By default, the maximum cache idle time is 48 hours.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node Name-
Use this parameter to display information only about the specified node.
[-vserver <vserver>]
- Vserver-
Use this parameter to display information only about the specified vserver.
[-data-lif-ip <IP Address>]
- Data LIF IP Address-
Use this parameter to display information only about the specified data LIF IP.
[-client-ip <IP Address>]
- Client IP Address-
Use this parameter to display information only about the specified client IP.
[-volume <volume name>]
- Volume Accessed-
Use this parameter to display information only about the specified volume.
[-protocol <Client Access Protocol>]
- Protocol Version-
Use this parameter to display information only about the specified protocol.
[-idle-time <[<integer>d][<integer>h][<integer>m][<integer>s]>]
- Idle Time (Sec)-
Use this parameter to display the time elapsed since the client sent the last request for this volume.
[-local-reqs <integer>]
- Number of Local Reqs-
Use this parameter to display a counter tracking requests that are sent to the volume with fast-path.
[-remote-reqs <integer>]
- Number of Remote Reqs-
Use this parameter to display a counter tracking requests that are sent to the volume with slow-path to remote Dblade using a CSM session.
[-policy-name <text>]
- Export Policy Name-
Use this parameter to display the Policy Name for this volume.
[-trunking-status {true|false}]
- Trunking Status-
Use this parameter to display trunking status for the specified client/connection.
The following example displays the connected clients information.
cluster-1::*> nfs connected-clients show Node: vsim1 Vserver: vs1 Data-Ip: 10.140.72.214 Client-Ip Protocol Volume Policy Idle-Time Local-Reqs Remote-Reqs -------------- -------- --------- -------- ------------ ---------- ---------- 10.140.137.57 nfs4 rvol1 pol1 5s 9 0 10.140.137.57 nfs3 vol1 pol1 6m 51s 14 0 10.140.137.57 nfs4 vol1 pol1 5s 16 0 3 entries were displayed.
