ONTAP commands
vserver nfs connected-clients show
Display List of recent NFS clients information
The `nfs connected-clients show ` command displays information about currently connected NFS clients, other NFS clients that are are currently idle but can be connected, and a list of recently unmounted clients.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node Name
Use this parameter to display information only about the specified node.
[-vserver <vserver>] - Vserver
Use this parameter to display information only about the specified vserver.
[-data-lif-ip <IP Address>] - Data LIF IP Address
Use this parameter to display information only about the specified data LIF IP.
[-client-ip <IP Address>] - Client IP Address
Use this parameter to display information only about the specified client IP.
[-volume <volume name>] - Volume Accessed
Use this parameter to display information only about the specified volume.
[-protocol <Client Access Protocol>] - Protocol Version
Use this parameter to display information only about the specified protocol.
[-idle-time <[<integer>d][<integer>h][<integer>m][<integer>s]>] - Idle Time (Sec)
Use this parameter to display the time elapsed since the client sent the last request for this volume.
[-local-reqs <integer>] - Number of Local Reqs
Use this parameter to display a counter tracking requests that are sent to the volume with fast-path.
[-remote-reqs <integer>] - Number of Remote Reqs
Use this parameter to display a counter tracking requests that are sent to the volume with slow-path to remote Dblade using a CSM session.
[-policy-name <text>] - Export Policy Name
Use this parameter to display the Policy Name for this volume.
The following example displays the connected clients information.
cluster-1::*> nfs connected-clients show
Node: vsim1
  Vserver: vs1
  Data-Ip: 10.140.72.214
Client-Ip      Protocol Volume    Policy   Idle-Time    Local-Reqs Remote-Reqs
10.140.137.57  nfs4     rvol1     pol1     5s           9          0
10.140.137.57  nfs3     vol1      pol1     6m 51s       14         0
10.140.137.57  nfs4     vol1      pol1     5s           16         0
3 entries were displayed.
